NetApp Knowledge Base
SWS and FPolicy: Frequently Asked Questions
13
Visibility:
Votes:
0
Category:
data-infrastructure-insights
Specialty:
oci
Last Updated:
Applies to
  • Storage Workload Security (SWS)
  • Data Collector (DC)
  • SAN (Storage Area Network) Protocol
  • NAS (Network Attached Storage) Protocol
  • iSCSI (Internet Small Computer System Interface) Protocol
  • FCP (Fibre Channel Protocol)
  • SVM (Storage Virtual Machine) a.k.a vServer
  • SMB (Server Message Block) Protocol
  • CIFS (Common Internet File System) Protocol
  • Fpol (Fpolicy)
Answer
Question Answer
Can SWS DC support SAN protocol (iSCSI & FCP)? No
Can SWS DC support NAS protocol (NFS & SMB/CIFS)? Yes
How many SWS DC needed to be created to monitor / audit "3 - SVMs" on a cluster? 3
Types of SWS DC? ONTAP DC & User Directory Collector
If user directory collector is failing, did it impact ONTAP DC? No
How many Fpol will be create per protocol in ONTAP per SVM?
2 - Fpol per protocol per SVM
::*> vserver fpol show -vserver <vserver_name>
SWS Fpol naming convention seen in ONTAP?
cloudsecure_<vserver><priority_number>_policy
::*> vserver fpol show-enabled -vserver <vserver_name>
How to check the Fpol status (on/off) on a vServer? ::*> vserver fpol show -vserver <vserver_name>
Is it normal in a 2-node cluster, we see "disconnected" server status on node 1b?
Yes
::*> vserver fpol show-engine -vserver svm1
                                                    FPolicy           Server         Server
Vserver Policy Name                     Node         Server            Status         Type
svm1    cloudsecure_svm11_policy  cluster-1a        10.2.2.35       connected      primary
svm1    cloudsecure_svm13_policy  cluster-1a        10.2.2.35       connected      primary
svm1    cloudsecure_svm12_policy  cluster-1a        10.2.2.35       connected      primary
svm1    cloudsecure_svm14_policy  cluster-1a        10.2.2.35       connected      primary
svm1    cloudsecure_svm11_policy  cluster-1b        10.2.2.35      disconnected    primary
svm1    cloudsecure_svm13_policy  cluster-1b        10.2.2.35      disconnected    primary
svm1    cloudsecure_svm12_policy  cluster-1b        10.2.2.35      disconnected    primary
svm1    cloudsecure_svm14_policy  cluster-1b        10.2.2.35      disconnected    primary
8 entries were displayed.
How to check what ports are used by Fpol engine? ::*> vserver  fpol pol external-engine  show -vserver <vserver_name>
Can i pause the user directory collector in SWS? No
Can i pause the ONTAP DC in SWS?
Yes [Manually from SWS UI]
Note: Pausing ONTAP data collector in SWS using API is not available at this time
If i pause the ONTAP DC in SWS, what will happen to Fpol in ONTAP? Fpol will be remove from SVM (vserver), Fpol will be re-added again when you resume the ONTAP DC.
What is the name of SWS agent service and how to check the status?
cmd > systemctl status cloudsecure-agent.service
