NetApp Knowledge Base
How does the OnCommand Insight and Data Infrastructure Insights discover all fabric switches feature work with Brocade switches?
265
Visibility:
Votes:
0
Category:
data-infrastructure-insights
Specialty:
oci
Last Updated:
Applies to
  • OnCommand Insight (OCI)
  • Data Infrastructure Insights (DII) (formerly Cloud Insights)
  • Brocade Switch
Answer
  • The OCI / DII data source will SSH to the switch you specify in the data source configuration.
  • OCI / DII will inventory that switch and perform a fabricShow command.
    • With the fabric discovery feature enabled, OCI will parse the fabricShow output looking for MAC Adress of switches
    • OCI / DII will try to determine the WWN of the switch if it is a Brocade device.
  • After inventorying the first Brocade switch, the data source will then move to SSH-ing to the next Brocade switch it has learned about.
