NetApp Knowledgebase
What are the frequently asked questions about SolidFire Drives?
178
Visibility:
Votes:
0
Category:
sf-series
Specialty:
solidfire
Last Updated:
Applies to
  • SolidFire
Answer
  1. How do I go about replacing a SolidFire Drive?
  • Contact SolidFire Technical Support.
  • SolidFire will supply replacement drives upon any drive failure. It is recommended to have one spare drive per every five nodes.
  1. Can I be responsible for destroying my own failed drives under SolidFire's drive replacement policy?
  • Yes, however there is an additional cost that comes along with drive replacement.
  1. Does SolidFire do anything special to prevent premature wear and help drive endurance?
  • Yes - SolidFire works directly with SSD manufacturers to provide
    • write endurance internally
    • sequentially writing the whole SSD
    • performing periodic "Garbage Collection" to more evenly "wear" across the whole of the SSD.
  • SolidFire's algorithm provides advances on top of manufacturer's wear leveling to exceed the typical manufacture's failure rates.
  1. Does SolidFire allow for on-site spares of drives?
  • Yes - Customer must purchase onsite spares.
  1. Can I use my own SSD drives within a SolidFire node/cluster?
  • No - SolidFire's architecture allows only for specific drive sizes and manufacturers.
  1. How do I know how full a drive is?
  • SolidFire's UI and API calls allow a user to poll a given drive for drive utilization. eg.)
 https://192.168.0.101/json-rpc/10.0?method=GetDriveStats&driveID=37
This will display something like the following,
result: {
driveStats: {
driveID: 37,
failedDieCount: 0,
lifeRemainingPercent: 100,
lifetimeReadBytes: 1677084065792,
lifetimeWriteBytes: 1621115273216,
powerOnHours: 49307,
readBytes: 0,
readOps: 0,
reallocatedSectors: 0,
reserveCapacityPercent: 100,
timestamp: "2019-06-12T08:03:35.155099Z",
totalCapacity: 300069052416,
uncorrectableErrors: 0,
usedCapacity: 0,
usedMemory: 264261632,
writeBytes: 0,
writeOps: 0
7. Does SolidFire do predictive drive failure?
  • No - Given SolidFire's architecture, it is best to let a component fail completely versus trying to prevent the failure.
Additional Information
NA
