NetApp Knowledge Base
E-Series AutoSupport message delivery failed with HTTP status code 409
461
Visibility:
Votes:
0
Category:
e-series-santricity-web-services-proxy
Specialty:
esg
Last Updated:
Applies to
  • NetApp E-Series
  • Platforms: E2800, E5700 and associated EF-series
Issue
  • The user received daily alerts via email indicating AutoSupport delivery is failing:
An ASUP message could not be delivered from the array management host eos-b to NetApp ASUP https gateway https://support.netapp.com/put/AsupPut/
  • E-Series web-server-trace-log-B log file provides additional details about the AutoSupport failure. The AutoSupport upload is failing with HTTP status code 409.
2021-12-06 04:16:00,953 INFO [SMMonitorTask-3145] trace [DuplicateDispatchHandler.java:699] [requestId=0, deviceId=N/A] Found Matching record for 12-05-2021, slot : 17
2021-12-06 04:16:02,056 INFO [SMMonitorTask-3145] trace [ASUPHTTPClient.java:983] [requestId=0, deviceId=N/A] Connecting to HTTPS proxy server: xx.xx.xx.xx:xxx, IP xx.xx.xx.xx
2021- 12-06 04:16:02,058 INFO [SMMonitorTask-3145] trace [ASUPHTTPClient.java:990] [requestId=0, deviceId=N/A] Proxy tunnel to server: support.netapp.com:443
2021-12-06 04:16:02,336 INFO [SMMonitorTask-3145] trace [ASUPHTTPClient.java:1367] [requestId=0, deviceId= N/A] Reading file '/msw_data/data/monitor/supportdata/pending/BUNDLE.Daily.6D039EA000209E97000000005FBD0A
08.AIOMOSTL6SG104. 1638673136367.7z' and writing to output stream
2021-12-06 04:16:04,434 ERROR [SMMonitorTask-3145] trace [ASUPHTTPClient.java:701] [requestId=0, deviceId=N/A] ASUP message upload failed, status code 409
Caller 0 at smmonitor.asup.ASUPHTTPClient. dispatchASUPMessage(ASUPHTTPClient.java:701)
Caller 1 at smmonitor.asup.ASUPTask.dispatchAutoSupportBundle(ASUPTask.java: 1720)
Caller 2 at smmonitor.asup.ASUPTask.doTaskOperation(ASUPTask.java:1411)
Caller 3 at smmonitor.asup.ASUPTask. doTask(ASUPTask.java:1315)
Caller 4 at smmonitor.asup.ASUPTask.doTask(ASUPTask.java:44)
2021-12-06 04:16:04,434 ERROR [SMMonitorTask-3145] trace [ASUPTask.java:1731] [requestId=0, deviceId=N/A] Dispatching ASUP Bundle is failed
New to NetApp?
