NetApp Knowledge Base
E-Series: How to troubleshoot 'Assigned drive or hot spare-in use drive removed' event
1,848
Visibility:
Votes:
1
Category:
e-series-santricity-os-controller-software
Specialty:
esg
Last Updated:
Applies to
  • E-Series Controller Firmware 7.xx
  • E-Series Controller Firmware 8.xx
This event occurs when an assigned drive or hot spare-in use is removed. This event also occurs in instances when a failed drive is removed in order to facilitate a drive replacement.
This means that not every instance of the event indicates a new issue, and this error message is often expected especially during a drive replacement.
Due to the fact that this is a critical MEL event, it results in the generation of a new ASUP and often an automatically generated Technical Case.
New to NetApp?
