NetApp Knowledge Base
X1146A ports not coming online
677
Visibility:
Votes:
0
Category:
aff-series
Specialty:
HW
Last Updated:
Applies to
  • MetroCluster IP
  • AFF A400
  • X1146A: Dual 40/100G Ethernet T62100-CR card
  • Cisco N3K-C3132Q-V
Issue
  • Ports remain down when connected with cable to switch
sysconfig -a output
	slot 2: Dual 40/100G Ethernet T62100-CR
		e2a MAC Address:    00:07:43:66:29:90 (auto-unknown-fd-down)
		e2b MAC Address:    00:07:43:66:29:98 (auto-unknown-fd-down)
		Device Type:        T6 2
		Firmware Version:   1.24.12.0
		Part Number:        110122860D0
		Hardware Revision:  0
		Serial Number:      PT19210369
	slot 3: Dual 40/100G Ethernet T62100-CR
		e3a MAC Address:    00:07:43:66:29:d0 (auto-unknown-fd-down)
		e3b MAC Address:    00:07:43:66:29:d8 (auto-unknown-fd-down)
		Device Type:        T6 2
		Serial Number:      PT19210366
  • Cards are correctly detected in sysconfig -ac
::> system node run -node NodeA -command sysconfig -ac
sysconfig: slot 1 OK: X1146A: Dual 40/100G Ethernet T62100-CR
sysconfig: slot 2 OK: X1146A: Dual 40/100G Ethernet T62100-CR
sysconfig: slot 3 OK: X1146A: Dual 40/100G Ethernet T62100-CR
sysconfig: No shelf configuration errors detected.
sysconfig: There are no configuration errors.
  • Loopback test confirms ports come online
  • Tested ports using replacement optical and copper cables to rule out bug 1411966
New to NetApp?
