NetApp Knowledge Base
Newly added FIPs disks report as 'nonencrypting drive or non-FIPS-certified drive'
526
Visibility:
Votes:
0
Category:
aff-series
Specialty:
HW
Last Updated:
Applies to
  • FAS
  • AFF
  • ONTAP 9
  • FIPs Drives
  • NSE Drives
  • X358_SLBPE3T8ATE
Issue
  • After adding new shelf of FIPS enabled X358_SLBPE3T8ATE drives, all drives show as failed.
slot 0: SAS Host Adapter 0a (PMC-Sierra PM8070 rev. C, SAS, <UP>)
    Firmware rev:       03.08.09.00
    Base WWN:           5:00a098:0038a6d:30
    Phy State:          [0] Enabled, 12.0 Gb/s
                        [1] Enabled, 12.0 Gb/s
                        [2] Enabled, 12.0 Gb/s
                        [3] Enabled, 12.0 Gb/s
    Mini-SAS HD Vendor:        Amphenol
    Mini-SAS HD Part Number:   112-00435+A0
    Mini-SAS HD Type:          Passive Copper (unequalized) 0.5m ID:01
    Mini-SAS HD Serial Number: APF16454005221
     ID     Vendor   Model            FW    Size
    00.0 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.1 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.2 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.3 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.4 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.5 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.6 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.7 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.8 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.9 : NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.10: NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
    00.11: NETAPP   X358_SLBPE3T8ATE NA50 3662.5GB (781422768 520B/sect) (Failed)
  • EMS logs display that the drives are not FIPs certified:
[XXXXX:disk.encryptSupportReqd:ALERT]: Detected nonencrypting drive or non-FIPS-certified drive 0a.XX.XX, but only FIPS-certified drives are supported on this node. 84 of 96 drives checked are FIPS-certified
New to NetApp?
