NetApp Knowledge Base
How ONTAP monitors the CRCs?
1,148
Visibility:
Votes:
0
Category:
not set
Specialty:
HW
Last Updated:
Applies to
  • Ethernet protocol. IEEE 802.3
  • CRC or Frame check sequence
Answer
  • ONTAP reports CRC errors when corrupted frames are received.
  • ifstat output and AutoSupport section:
::> system node run -node node-name ifstat e0c
-- interface  e0c  (7 days, 18 hours, 10 minutes, 41 seconds) --
RECEIVE
 Total frames:    508k | Frames/second:     1  | Total bytes:   37009k
 Bytes/second:     55  | Total errors:   12117 | Errors/minute:     0
 Total discards:    0  | Discards/minute:   0  | Multi/broadcast: 1280k
 Non-primary u/c:   0  | CRC errors:     12117 | Runt frames:       0
 Long frames:       0  | Length errors:     0  | Alignment errors:  0
 No buffer:         0  | Pause:             0  | Jumbo:             0
  • Event message and EMS AutoSupport message:
Wed Jun 30 02:38:27 CEST [node-name: vifmgr: vifmgr.cluscheck.crcerrors:alert]: Port e0c on node node-name is reporting a high number of observed hardware errors, possibly CRC errors.
  • ONTAP reports CRC errors in event messages and EMS AutoSupport messages when getting more than 1 in 1000 frames.
Additional Information
  • CRC errors are usually caused by faulty hardware or incompatible hardware
  • Network switches can willingly forward bad CRC frames
  • Packet trace is not useful
