Can AFF A250 nodes be added to a cluster running Ontap older than 9.8?
Applies to
- AFF A250
- ONTAP 9
Answer
- According to HWU the lowest version (oldest) of Ontap the AFF A250 supports is 9.8.
- If the The ONTAP version of the other cluster is older than 9.8, the other cluster will need to be upgraded, before the AFF A250 nodes can join the cluster.
