NetApp Knowledge Base
Adapter cards not present when adding expansion cards, error "monitor.ioCard.degraded"
679
Visibility:
Votes:
1
Category:
not set
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • AFF A700
  • AFF A900
  • FAS9000
  • FAS9500
Issue
When adding expansion cards in platforms under the Applies section, cards may not show up in the "sysconfig -ac".  Errors simliar to below are also seen on console and in EMS logs:
Jun 03 19:42:40 [Cluster-01:monitor.ioCard.degraded:ALERT]: IO card is degraded: IO3 SAS Power Good Power Fault.
Jun 03 19:42:40 [Cluster-01:monitor.ioCard.degraded:ALERT]: IO card is degraded: IO3 SAS Hot Swap Cur is critical low (0 mA).
Jun 03 19:42:40 [Cluster-01:monitor.ioCard.degraded:ALERT]: IO card is degraded: IO11 SAS Power Good Power Fault.
Jun 03 19:42:40 [Cluster-01:monitor.ioCard.degraded:ALERT]: IO card is degraded: IO11 SAS Hot Swap Cur is critical low (0 mA).
Jun 03 19:42:50 [Cluster-01:monitor.ioCard.degraded:ALERT]: IO card is degraded: IO11 SAS P3.3V is not readable
Jun 03 19:42:50 [Cluster-01:monitor.ioCard.degraded:ALERT]: IO card is degraded: IO11 SAS P1.8V is not readable
Jun 03 19:42:50 [Cluster-01:monitor.ioCard.degraded:ALERT]: IO card is degraded: IO11 SAS P1.0V is not readable
Jun 03 19:42:50 [Cluster-01:monitor.ioCard.degraded:ALERT]: IO card is degraded: IO11 SAS P0.9V is not readable
Jun 03 19:42:50 [Cluster-01:monitor.ioCard.degraded:ALERT]: IO card is degraded: IO11 SAS 5V Standby is not readable
Jun 03 19:43:11 [Cluster-01:monitor.ioCard.degraded:ALERT]: IO card is degraded: IO3 SAS P3.3V is not readable
Jun 03 19:43:12 [Cluster-01:monitor.ioCard.degraded:ALERT]: IO card is degraded: IO3 SAS P1.8V is not readable
Jun 03 19:43:12 [Cluster-01:monitor.ioCard.degraded:ALERT]: IO card is degraded: IO3 SAS P1.0V is not readable
Jun 03 19:43:12 [Cluster-01:monitor.ioCard.degraded:ALERT]: IO card is degraded: IO3 SAS P0.9V is not readable
Jun 03 19:43:12 [Cluster-01:monitor.ioCard.degraded:ALERT]: IO card is degraded: IO3 SAS 5V Standby is not readable
New to NetApp?
