NetApp Knowledge Base
Windows Server 2012 Failover Cluster validation tests fail for Storage Pools
628
Visibility:
Votes:
6
Category:
flexpod-with-infrastructure-automation
Specialty:
san
Last Updated:
Applies to
  • SAN
  • FlexPod
Issue
Failover Cluster validation testing might report a failure against a connected LUN similar to the following:
Test Disk 1 does not support SCSI-3 Persistent Reservations commands needed to support clustered Storage Pools. Some storage devices require specific firmware versions or settings to function properly with failover clusters. Please contact your storage administrator or storage vendor to check the configuration of the storage to allow it to function properly with failover clusters.
New to NetApp?
  • Was this article helpful?
