NetApp Knowledge Base
What is the upgrade path for the NetApp supported Cisco Ethernet Switches?
2,196
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
HW
Last Updated:
Applies to
Cisco Ethernet Switch upgrade path
Answer
Unless an exception is identified, the order of installation or upgrade for cluster network switch software is as follows:
  1. NX-OS
  2. Cisco RCF
NetApp Ethernet Switch Guide
  • The Cisco Ethernet Switch  table will map out the supported Cisco switch models, NX-OS software releases, reference configuration file (RCF) versions, and ONTAP releases for cluster networks.
  • Reference Upgrading ONTAP 9 Cluster Network Switch for information about installing NX-OS firmware, reference configuration files (RCF), and ONTAP releases for the specific switch models.
    • The exact upgrade path can be found in the release notes of the version you want to upgrade to
