NetApp Knowledge Base
How to determine the NetApp part number for a power supply (PS / PSU) or fan for Brocade switch
6,040
Visibility:
Votes:
2
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
Applies to
  • SAN
  • MetroCluster switches
  • Brocade switches  G720, G620, G630, 6520, 6510, 6505, 5100, X6-4 and X6-8
  • Brocade Backbone DCX8510
Faulty power supply or fan reported on Brocade 6520, 6510, 6505 or 5100 switch:
Faulty power supply reported by Brocade DCX8510 Backbone
  • Faulty PS reported:
psshow :
Power Supply #1 is OK
Airflow Direction : Port side Exhaust (Reverse)
Power Supply #2 is faulty*
* = No system control access to power supply.
  • Faulty fan reported:
fanshow        :
Fan 1 is Ok, speed is 4071 RPM
Fan 2 is faulty
Fan 3 is Ok, speed is 4119 RPM
Fan 4 is Ok, speed is 18977 RPM
Fan 5 is Unknown
  • Faulty power supply or fan reported on Brocade X6-4 and Brocade X6-8:
psshow        :
V10N18,   DUCXXXXXXHJ      ,23-0000161-01,A0,DELTA,ECXXXXXXX42     ,00,DUXXXX8N
V10N22,   DUCXXXXXX1H      ,23-0000161-01,A0,DELTA,ECXXXXXXX42     ,00,DUXXXX2N
fanshow        :
Fan 1 is Ok, speed is 4067 RPM
Fan 2 is faulty
Fan 3 is Ok, speed is 4067 RPM
  • Brocade X6-4 Director: Two fan assemblies, non-port side exhaust or intake, for 1+1 redundancy. Each assembly contains 2 fans for a total of 4. The system requires 3 out of 4 functioning fans for operation. One fan assembly can be hot-swapped but must be replaced immediately.
  • Brocade X6-8 Director: Three fan assemblies, non-port side exhaust or intake, for 2+1 redundancy. Each assembly contains 2 fans for a total of 6. The system requires 5 out of 6 functioning fans for operation. One fan assembly can be hot-swapped but must be replaced immediately.
  • Brocade 6505: switch also comes with an option for a single hot-swappable PS unit. Failure of this power supply will bring the switch down and no LED light would be seen.
  • Brocade DCX8510 Backbone
xxxxx20 Power Supply #1 is faulty Brocade DCX8510-8  WWN Serial Num: AFXxxxxL00K     Power Supply #1 is faulty
POWER SUPPLY  Unit: 1
Header Version:         2
Power Consume Factor:   0
Factory Part Num:       23-0000067-02
Factory Serial Num:     AGCxxxxLB8Z
New to NetApp?
