NetApp Knowledge Base
IO FPGA fails to upgrade on Cisco Nexus switches
2,044
Visibility:
Votes:
2
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
Applies to
  • Cisco Nexus 3232C
  • Cisco Nexus 92300YC
  • Cisco Nexus 9336C-FX2
Issue
While updating the EPLD image on the switch models in the "applies to" section, the IO FPGA EPLD device shows as the device is programming the upgrade; however, post reboot the device does not show the updated version:
switch1# install epld bootflash:n9000-epld.9.3.4.img module 1
Compatibility check:
Module Type Upgradable Impact Reason
 1 SUP Yes disruptive Module Upgradable
Retrieving EPLD versions.... Please wait.
Images will be upgraded according to following table:
Module  Type   EPLD             Running-Version   New-Version  Upg-Required
     1   SUP  MI FPGA                   0x9        0x12            Yes
     1   SUP  IO FPGA                   0x9        0x12            Yes
The above modules require upgrade.
The switch will be reloaded at the end of the upgrade
Do you want to continue (y/n) ? [n] y
Proceeding to upgrade Modules.
Starting Module 1 EPLD Upgrade
Module 1 : MI FPGA [Programming] : 100.00% (     64 of      64 sectors)
Module 1 : IO FPGA [Programming] : 100.00% (     64 of      64 sectors)
Module 1 EPLD upgrade is successful.
Module Type Upgrade-Result
 1 SUP Success
Output after reboot:
switch1# show version module 1 epld
EPLD Device Version
MI FPGA 0x12
IO FPGA 0x9
New to NetApp?
