NetApp Knowledgebase
Brocade Switch is in hung state with transient i2c faults
70
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
san
Last Updated:
Applies to
Brocade 6520
Prior to v7.3.1a or v7.4.0
Issue
I2C access failures leading to various symptoms such as:
  1. slotshow command output may flag some components with an "*", indicating no i2c access to that component.
  2. switchshow command output may indicate “Speed Mismatch / Incompatible SFP
  3. tempshow command output may display "unknown"
  4. Console log (dmesg) may include:
pcf954x_select_mux: Failed to select the I2C mux (addr=76, val=08, err=-1 id=0)!
• In the RAS logs, look for the below errors.
 [HIL-5010], 17389714/0, CHASSIS, WARNING, Brocade6520, Warning, license id access problems (-4)!!, hil_sb_wwn_conf, line:   232, comp:secd,
 [LIC-5015], 17389715/0, CHASSIS, ERROR, Brocade6520, Failed to get WWN from HIL. Return code -4 . , id.c, line: 80,      comp:secd,
 [LIC-5002], 17389716/0, CHASSIS, ERROR, Brocade6520, Error reading license records. , db.c, line: 314, comp:secd,
 [EM-5010], 17389717/0, CHASSIS, WARNING, Brocade6520, wwn card slot_out ignored for onboard fru seeprom, OID:0x46100000,   power.c, line: 3414, comp:emd,
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
