NetApp Knowledge Base
Brocade SanNav zoning function is not updated properly
666
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
san
Last Updated:
Applies to
  • Brocade
  • SanNav 2.1
Issue
  • Created new zone aliases and zones through SANnav Portal
  • While editing the Defined Zone configuration, the zone configuration does not change from Defined to Modified.
  • After opening the defined configuration, the zone(s) that were previously removed, are still present.
  • While creating new Zone Aliases, the Connected Product Port  names display the old value. However, under Inventory -> Storage Ports and on the SAN switch, these names are correct.
New to NetApp?
