NetApp Knowledge Base
Brocade SFP shows low laser power as per TSB 2019-274-A1
1,051
Visibility:
Votes:
5
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
Applies to
  • Brocade Fibre Channel (FC) switches
  • Brocade SFP with NetApp part number X-000212
  • Brocade Technical Support Bulletin TSB 2019-274-A [1]
Issue
  • Brocade SFP with NetApp part number X-000212 shows low transmitted (TX) laser power
  • Latency may be observed on hosts connected via the SFP with the low TX laser power
  • Errors may be observed on host-side "Disks" that are LUNs connected via the SFP with low TX laser power
New to NetApp?
