BES-53248 RCF configuration validation fails while applying the script
Applies to
- BES-53248 Cluster Network Switch
- RCF
- EFOS
Issue
BES-53248 Cluster RCF validation error:
(switch)# script apply BES-53248_RCF_v1.7-Cluster-HA.scr … Configuration script validation failed. Following lines in the script may have problem: Line 55:: police-simple rate-percent 60 64 conform-action transmit violate-action transmit Line 59:: police-simple rate-percent 60 64 conform-action transmit violate-action transmit Line 68:: police-simple rate-percent 60 64 conform-action transmit violate-action transmit Line 72:: police-simple rate-percent 60 64 conform-action transmit violate-action transmit The file being downloaded has potential problems. Do you want to save this file? (y/n)
