NetApp Knowledge Base
checksum errors on mutliple disks in a fabric metrocluster
356
Visibility:
Votes:
0
Category:
metrocluster
Specialty:
MetroCluster
Last Updated:
Applies to
  • Fabric Metrocluster
  • ONTAP 7 mode
Issue
  • Multiple drives reporting checksum errors from multiple nodes
Mon Nov 15 11:43:36 CET [node-01: disk_server_0: disk.checksum.verifyFailed:error]:  Disk level checksum verification failed on WRITE VERIFY: Disk sw4:5.126L132, Block #90468901: Volume vol1,  FileId 73, Block #6465
Mon Nov 15 11:43:42 CET [node-01: disk_server_1: disk.checksum.verifyFailed:error]:  Disk level checksum verification failed on WRITE VERIFY: Disk sw4:5.126L38, Block #197881793: Volume vol2,  FileId 101, Block #38003369
Mon Nov 15 11:43:42 CET [node-01: disk_server_0: disk.checksum.verifyFailed:error]:  Disk level checksum verification failed on WRITE VERIFY: Disk sw4:5.126L45, Block #214050274: Volume vol3,  FileId 97, Block #1853207023
Mon Nov 15 11:43:56 CET [node-01: disk_server_0: disk.checksum.verifyFailed:error]:  Disk level checksum verification failed on WRITE VERIFY: Disk sw4:5.126L152, Block #218915150: Volume vol4,  FileId 101, Block #1046572
Mon Nov 15 11:44:01 CET [node-01: disk_server_0: disk.checksum.verifyFailed:error]:  Disk level checksum verification failed on WRITE VERIFY: Disk sw4:5.126L185, Block #84031152: Volume vol5,  FileId 97, Block #1304767822
Mon Nov 15 11:44:08 CET [node-01: disk_server_0: disk.checksum.verifyFailed:error]:  Disk level checksum verification failed on WRITE VERIFY: Disk sw4:5.126L254, Block #9475108: Volume vol5,  FileId 97, Block #594239028
Mon Nov 15 11:44:15 CET [node-01: disk_server_0: disk.checksum.verifyFailed:error]:  Disk level checksum verification failed on WRITE VERIFY: Disk sw4:5.126L248, Block #209441865: Volume vol6,  FileId 101, Block #6735845
Mon Nov 15 11:44:27 CET [node-01: disk_server_0: disk.checksum.verifyFailed:error]:  Disk level checksum verification failed on WRITE VERIFY: Disk sw4:5.126L139, Block #179664210: Volume vol7, FileId 98,  Block #68726647296
Mon Nov 15 11:44:36 CET [node-01: disk_server_1: disk.checksum.verifyFailed:error]:  Disk level checksum verification failed on WRITE VERIFY: Disk sw4:5.126L132, Block #6005141: Volume vol4,  FileId 101, Block #1048263
Mon Nov 15 11:44:42 CET [node-01: disk_server_0: disk.checksum.verifyFailed:error]:  Disk level checksum verification failed on WRITE VERIFY: Disk sw4:5.126L242, Block #165234200: Volume vol8,  FileId 97, Block #1084249415
Mon Nov 15 11:46:04 CET [node-01: disk_server_1: disk.checksum.verifyFailed:error]:  Disk level checksum verification failed on WRITE VERIFY: Disk sw4:5.126L239, Block #190357718: Volume vol5,  FileId 97, Block #1861448895
  • Drives may also be failing
  • All errors are reported are coming from same switch
  • No errors seen in ATTO bridge logs or switch logs
New to NetApp?
