NetApp Knowledge Base
Why the result of linux commands "df" and "du" are different after deleting file?
25,699
Visibility:
Votes:
21
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • ONTAP 9
  • NFS
Answer
  • du walks through the target and counts the space usage of each object
    • The target can be a directory, subdirectory, file, or the entire filesystem
  • df queries the filesystem for the current space usage
Additional Information
  • When objects are deleted, they are unlinked from the filesystem
    • Unlinked objects take up space until their blocks are reclaimed, but the objects are no longer reported to clients
    • du will report space usage as if the blocks have been reclaimed
    • df will slowly show changes in space usage as the blocks of the deleted object(s) are reclaimed
