NetApp Knowledge Base
What is the ONTAP e0S interface?
3,738
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
All platforms that do not have e0M-16
Answer
The e0S interface is an interface in newer FAS and AFF storage systems.
Conceptually, e0S is an ONTAP interface on a node that is used for internal communication with its service processor (SP) or baseboard management controller (BMC).
  • It is auto-configured with hard-coded IP addresses in the 192.0.2.x subnet.
  • On most platforms, it is used for SP/BMC firmware updates and error condition reporting directly between the SP/BMC and ONTAP internally
  • On many BMC-based platforms, this internal subnet is used for HW-assisted storage failover, as well (since both nodes' e0S interfaces and BMCs can see each other internally).
Details
  • A private and internal Ethernet-switched subnet exists between both ONTAP HA partners and both BMCs:
    • ONTAP interface: e0S
    • BMC interface: Either eth0 or eth1, depending on the platform model
  • Uses subnet 192.0.2.0/24 with statically-assigned IP addresses for all interfaces
  • Features such as HW-assisted failover, ONTAP <-> BMC communications (IPMI), and BMC FW updates are performed over this private network
  • Boot media replacements for these platforms will use the e0S IP address for the system node restore-backup command
  • HW-assisted takeover is not configurable – it uses statically-assigned addresses (see the table, below)
The IP addressing is static and automatically configured on all related Ethernet interfaces:
Controller e0S Address/Mask BMC Address/Mask
A 192.0.2.84/24 192.0.2.81/24
B 192.0.2.85/24 192.0.2.82/24
      Additional Information
      What is the ONTAP e0M-16 interface?
