NetApp Knowledge Base
What is the default and maximum value of bootarg.watch.max_concurrent_posts?
328
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
ONTAP 9
Answer
From ONTAP 9.2 and later, the values are changed.
  • The default number of watch post slots increases from 8 to 163.
  • The maximum value of the bootarg.watch.max_concurrent_posts bootarg increases from 96 to 2048.
Additional Information
Some applications might fail if the value of bootarg.watch.max_concurrent_posts sets too low.
Run the following command to change the value to match application's requirement:
node run -node * bootargs set bootarg.watch.max_concurrent_posts < new value >
