NetApp Knowledge Base
Weekly SPARES_LOW error for a Flash Pool or Storage Pool aggregate
1,073
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
Issue
  • After upgrading ONTAP to 9.7P14, the system triggers a warning once per week:
Fri Jun 25 11:53:00 +0200 [node-01: monitor: monitor.globalStatus.nonCritical:error]: There are no enough spare disks.
Fri Jun 25 12:00:00 +0200 [node-01: config_thread: callhome.spares.low:error]: Call home for SPARES_LOW
  • No drive failures.
  • No additional drives added to any of the existing hybrid aggregates.
  • The hybrid aggregate uses RAID4 groups:
Aggregate data_aggr (online, mixed_raid_type, hybrid) (block checksums)
  Plex /data_aggr/plex0 (online, normal, active, pool0)
    RAID group /data_aggr/plex0/rg0 (normal, block checksums, raid_dp)
    RAID group /data_aggr/plex0/rg1 (normal, block checksums, raid4)
      RAID Disk    Device      HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
      parity      0b.00.1P1    0b    0   1   SA:A   0   SSD   N/A 228853/468690944  228861/468707328
      data        0b.00.3P1    0b    0   3   SA:A   0   SSD   N/A 228853/468690944  228861/468707328
    RAID group /data_aggr/plex0/rg2 (normal, block checksums, raid4)
      parity      0b.00.1P2    0b    0   1   SA:A   0   SSD   N/A 228853/468690944  228861/468707328
      data        0b.00.3P2    0b    0   3   SA:A   0   SSD   N/A 228853/468690944  228861/468707328
  • No spare drives available for the RAID groups with  SSDs
New to NetApp?
