NetApp Knowledge Base
System reports single path under multi path cabling configuration using IOM6 and IOM12 modules
3,202
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • ONTAP 9
  • FAS / ASA / AFF platforms
  • Supported IOM6 / IOM12  stack mixing
Issue
  • System reports Single-Path when cabled for Multi-Path.
  • IOM6 and IOM12 are mixed in the same stack.
    • Verify compatibility: HWU . Go to Storage Limits > Full Storage Limit Matrix >Supported Shelves/Drives
  • If the cabling is not correct the system might trigger an EMS message similar to:
[Node-01: nchmd: hm.alert.raised:alert]: Alert Id = IOM12ToIOM6SquarePortConnection_Alert , Alerting Resource = 1234567..... raised by monitor node-connect
[Node-01: nchmd: hm.alert.raised:alert]: Alert Id = MixOfIOMAandIOMBConnection_Alert , Alerting Resource = 1234567.....:2 raised by monitor node-connect
[Node-01: nchmd: hm.alert.raised:alert]: Alert Id = SinglePathToDiskShelf_Alert , Alerting Resource = 1234567..... raised by monitor node-connect
  • The port where the IOM6 Square port is connected to will be disabled:
Shelf name:    Partner.shelf0
Shelf id:      0
Channel:       Partner
Module:        A
               Partial Path   Link    Invalid   Running     Loss    Phy       CRC     Phy
Disk    Port   Timeout        Rate     DWord    Disparity   Dword   Reset     Error   Change
Id     State   Value (ms)    (Gb/s)    Count    Count       Count   Problem   Count   Count
[SQR0] NO SIGNAL      7         NA        0           0       0        0         0       6
[SQR1] NO SIGNAL      7         NA        0           0       0        0         0       6
[SQR2] NO SIGNAL      7         NA        0           0       0        0         0       6
[SQR3] NO SIGNAL      7         NA        0           0       0        0         0       6
Shelf name:    0b.shelf1
Shelf id:      1
Channel:       0b
Module:        A
[HST8] DIS/ILLGL      7         NA        0           0       0        1         0       4
[HST9] DIS/ILLGL      7         NA        0           0       0        0         0       4
[HST10] DIS/ILLGL      7         NA        0           0       0        1         0       4
[HST11] DIS/ILLGL      7         NA        0           0       0        1         0       4
New to NetApp?
