NetApp Knowledge Base
PANIC : rlib_port_ipspace_assign: port e0a could not be moved to HA ipspace
559
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8300
  • FAS8700
  • AFF-A400
  • AFF-A800
  • ONTAP 9
  • Headswap
Issue
Panic occurs during headswap
Example:
(1) Normal Boot.
(2) Boot without /etc/rc.
(3) Change password.
(4) Clean configuration and initialize all disks.
(5) Maintenance mode boot.
(6) Update flash from backup config.
(7) Install new software first.
(8) Reboot node.
(9) Configure Advanced Drive Partitioning.
Selection (1-9)? 6
This will replace all flash-based configuration with the last backup to
disks. Are you sure you want to continue?: y
WARNING: System ID mismatch. This usually occurs when replacing a boot device or NVRAM cards!
Override system ID? {y|n} y
e0a: mlx5e_set_board_type port_name = e0a port_psid = NAP0000000006, device_id = 0x1017, vendor_id = 0x15b3
e0b: mlx5e_set_board_type port_name = e0b port_psid = NAP0000000006, device_id = 0x1017, vendor_id = 0x15b3
e0c: mlx5e_set_board_type port_name = e0c port_psid = NAP0000000005, device_id = 0x1017, vendor_id = 0x15b3
e0d: mlx5e_set_board_type port_name = e0d port_psid = NAP0000000005, device_id = 0x1017, vendor_id = 0x15b3
PANIC  : rlib_port_ipspace_assign: port e0a could not be moved to HA ipspace [err=92]
version: 9.7P18: Thu Mar 10 04:58:53 EST 2022
conf   : x86_64.optimize
cpuid = 12
Uptime: 1m29s
ahcich2: AHCI reset done: devices=00000001
coredump: primary dumper is not yet registered this early during system initialization. A coredump will not be available at this time.
coredump: secondary dumper is not yet registered this early during system initialization. A coredump will not be available at this time.
System halting...
New to NetApp?
