NetApp Knowledge Base
"Entering FM state:5" due to misconfigured bootarg.storageencryption.support
733
Visibility:
Votes:
0
Category:
aff-series
Specialty:
HW
Last Updated:
Applies to
  • AFF Models
  • FAS Models
  • ONTAP 9
  • FIPS or SED Drives
Issue
  • After hardware maintenance, node reports the following:
[localhost:disk.encryptNoSupport:ALERT]: Detected FIPS-certified encrypting drive 0n.4, but FIPS drives are not supported on this node. 48 of 48 disks checked are FIPS-certified.
or
Dec 01 14:34:15 [localhost:disk.encryptNoSupport:error]: Detected FIPS-certified encrypting disk 0b.00.3, but bootarg.storageencryption.support indicates that FIPS disks should not be present. 24 of 24 disks checked are FIPS disks.
  • The node continues to produce the following errors at waiting for giveback:
Waiting for giveback...(Press Ctrl-C to abort wait)Entering FM state:5 because mbFound:0 local in headswap:0
  • The cluster reports the following:
Cluster1::> storage failover show
Takeover
Node           Partner        Possible State Description
Cluster1-01    Cluster1-02    -        Kernel loaded
Cluster1-02    Cluster1-01    false    In takeover
2 entries were displayed.
New to NetApp?
