NetApp Knowledge Base
Node front attention LED on and Temperature Sensor show unavailable
713
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • FAS2720/AFF A220
  • FAS2750
  • BMC FW 11.7 or later
Issue
  • Attention LED set on by expander.
SP-LATEST-RUNTIME
FRU LEDs
status
FRU LED ID 1 is off
FRU LED ID 2 is on. Set by Expander
FRU LED ID 3 is off
FRU LED ID 4 is on
  • ses.status.temperatureWarning can be seen from EMS log.
Sun Aug 28 16:18:02 +0900 [node-01: dsa_worker1:ses.status.temperatureWarning:alert]: DS212-12 (S/N XXXXXX) shelf 0 on channel 0b temperature warning for Temperature sensor 14: not installed or failed. Current temperature: 54 C (129 F). This module is on the rear of the shelf at the top right, on shelf module B.
Sun Aug 28 16:18:02 +0900 [node-01: dsa_worker1: ses.status.temperatureWarning:alert]: DS212-12 (S/N XXXXXX) shelf 0 on channel 0b temperature warning for Temperature sensor 15: not installed or failed. Current temperature: 34 C (93 F). This module is on the rear of the shelf at the top right, on shelf module B.
  • Sensor 14,15 show unavailable at ENVIRONMENT.
Temperature Sensor installed element list: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15; with error: none
Shelf temperatures by element:
[1] 23 C (73 F) (ambient) Normal temperature range
[2] 31 C (87 F) Normal temperature range
[3] 31 C (87 F) Normal temperature range
[14] Unavailable
[15] Unavailable
New to NetApp?
