HA interconnect status shows down and can't giveback to partner node
Applies to
- ONTAP 9
- AFF systems
- ASA systems
- FAS systems
Issue
- Partner node was taken over, Waiting for giveback state.
"node-02" node state:
Waiting for giveback...(Press Ctrl-C to abort wait)- HA interconnect status show down
::*> system ha interconnect status show
Node: node-01
Link Status: down
IC RDMA Connection: down
Warning: Unable to list entries on node "node-02". RPC: Couldn't make connection
Error: show failed: RPC: Couldn't make connection- The "
storage failover show"command shows that operating node is "unknown"state.
::>storage failover show
Takeover
Node Partner Possible State
node-01 node-02 false In takeover
node-02 node-01 - Unknown
2 entries were displayed.- node-01 reported HA interconnect Initiating soft reset.
node-01: nic_mgr: cf.nm.nicReset:notice]: HA interconnect: Initiating soft reset on card 0 due to rendezvous reset.
