NetApp Knowledge Base
Fault LED of chassis is on and FANs are loud
257
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2650
  • FAS2750
  • Service Processor (SP)
  • Baseboard Management Controller(BMC)
Issue
  • Fans are loud.
  • environment status shows some temperature sensors are unavailable.
Example:
Temperature Sensor installed element list: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15; with error: none
Shelf temperatures by element:
  [1] 23 C (73 F) (ambient)  Normal temperature range
  [2] 27 C (80 F)  Normal temperature range
  [3] 27 C (80 F)  Normal temperature range
  [4] 28 C (82 F)  Normal temperature range
  [5] 28 C (82 F)  Normal temperature range
  [6] 27 C (80 F)  Normal temperature range
  [7] 28 C (82 F)  Normal temperature range
  [8] 27 C (80 F)  Normal temperature range
  [9] 29 C (84 F)  Normal temperature range
  [10] 35 C (95 F)  Normal temperature range
  [11] 47 C (116 F)  Normal temperature range
  [12] 28 C (82 F)  Normal temperature range
  [13] 37 C (98 F)  Normal temperature range
  [14] Unavailable
  [15] Unavailable
New to NetApp?
