NetApp Knowledge Base
FCP target adapter showing LINK DISCONNECTED due to faulty SFP on switch side
4,615
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
san
Last Updated:
Applies to
  • ONTAP 9
  • FCP
  • Brocade and Cisco SAN switches
Issue
  • Event log entry indicates an FC link is disconnected:
5/23/2020 21:11:31  cluster-node1  ERROR scsitarget.ispfct.linkBreak: Link break detected on Fibre Channel target adapter 1b. Firmware status code status1 0x2, status2 0x7, and status4 0x0.
  • sysconfg -a reports the port status as "Link Disconnected"
slot 1: Fibre Channel Target Host Adapter 1b
                (QLogic 8324 (8362) rev. 2, <LINK DISCONNECTED>)
                Board Name:        QLE2672
                Serial Number:     RFE2005W04482
                Firmware rev:      8.9.0
                Flash rev:         1.1.2
                Host Port Addr:    000000
                FC Nodename:       xx:0a:09:80:80:xx:xy:xx (500a098080b3a125)
                FC Portname:       xx:0a:09:82:80:xy:yy:xx (500a098280b3a125)
                Connection:        No link
                Switch Port:       Unknown
  SFP Vendor Name:   FINISAR CORP.
  SFP Vendor P/N:    FTLF8529P4BCV-QM
  SFP Vendor Rev:    B
  SFP Serial No.:    P2SABCS
  SFP Connector:     LC
  • Rx and Tx power shows as 0.0 (uWatts) for the Fibre Channel Target Adapter under FCP-Adapter.xml log in ASUP:
Rx : 0.0 (uWatts)
Tx : 0.0 (uWatts)
  • Rx and Tx power is optimal on either ends, storage and switch side.
port 9a
Rx : 623.0 (uWatts)
Tx : 1020.9 (uWatts)
Slot  9/Port  2:
RX Power:    -0.5    dBm (883.9uW)
TX Power:    -1.6    dBm (697.3 uW)
  • Network fcp adapter show command executed on CLI reports the operational status as "link disconnected"
cluster::> network fcp adapter show
                     Connection  Port      Admin   Operational
Node         Adapter Established Address   Status  Status
cluster-node1
             0c      false       0         up      link not connected
cluster-node1
             0d      false       0         up      link not connected
cluster-node1
             1a      true        f0500     up      online
cluster-node1
             1b      true        0         up      link disconnected
cluster-node2
cluster-node2
cluster-node2
             1a      true        f0600     up      online
cluster-node2
             1b      true        f0600     up      online
  • The storage HBA port is still physically connected
  • Below troubleshooting steps can be verified to isolate the issue:
    1. Verify the remote SFP health and bounce the port using below commands:
Cisco Example:
switch# config terminal
switch(config)# interface fc <slot>/<port#>
switch(config)# show int fc <slot>/<port#> transceiver detail
switch(config-if)# shutdown
switch(config-if)# no shutdown
Brocade Example:
switch:admin> sfpshow <index # OR slot/port #>
switch:admin> portdisable <index # OR slot/port #>
switch:admin> portenable <index # OR slot/port #>
  1. Perform physical inspection and re-seat link and patch panel components.
  2. Repeat port bounce process after re-seat.
  3. Replace/Swap components including cable and sfp on either ends.
New to NetApp?
