NetApp Knowledge Base
Event log shows "Controller failover of node_name is not possible: unsynchronized log"
1,184
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
FAS8080
Issue
The following error message occurs.
Thu Feb 18 02:15:06 JST [node2: monitor: monitor.globalStatus.critical:EMERGENCY]: Controller failover of node1 is not possible: unsynchronized log.
The interconnect port is at suboptimal speed.
Interconnect Port 1:
Port Name: ib0a
Default GID: xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx
Base LID: 0xed4
Active MTU: 4096
Data Rate: 10 Gb/s (4X) SDR
Link State: ACTIVE
QSFP Vendor: Molex Inc.
QSFP Part Number: 112-00374+A0
QSFP Type: Active Optical 5m ID:00
QSFP Serial Number: xxxxxxxxxxxxxx
Interconnect Port 2:
Port Name: ib0b
Base LID: 0xed5
Active MTU: 4096
Data Rate: 40 Gb/s (4X) QDR
Link State: ACTIVE
New to NetApp?
