NetApp Knowledge Base
Cannot disable CIFS auditing
922
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • ONTAP 9.x
  • CIFS auditing enabled
Issue
When attempting to disable CIFS auditing the command fails with the following error below:
::> vserver audit disable -vserver TheVserver
Error: command failed: Failed to disable auditing for Vserver "TheVserver". Reason: Audit consolidation job not present for the Vserver and one of the possible reasons might be snapmirror break operation in Vserver DR setup. Retry after some time.
::> vserver audit enable -vserver TheVserver
Error: command failed: Cannot enable auditing for Vserver "TheVserver". Reason: Auditing is already enabled for this Vserver.
New to NetApp?
