NetApp Knowledge Base
CPU0 Temp sensors show failed
1,022
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8200
  • AFF A300
Issue
  • Error is reported from event log show command. Example:
::> event log show
Time                Node             Severity      Event
2/12/2025 15:31:01  node_name         ERROR         monitor.temp.unreadable: The controller temperature (CPU0 Temp Margin) is not readable.
2/12/2025 15:31:01  node_name         EMERGENCY     monitor.globalStatus.critical:EMERGENCY: Chassis temperature is too high..
  • CPU0 Temp sensors show failed or invalid in SP-LATEST-IPMI. Example:
CPU0 Temp Avg            failed            -- C        --          --         -11 C        -1 C
InFlow Temp Avg          normal            23 C         0 C         5 C        50 C        55 C
PSU2                                      GOOD
CPU0 Temp Margin         failed            -- C        --          --         -11 C        -1 C
In Flow Temp             normal            23 C         0 C         5 C        50 C        55 C
New to NetApp?
