Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
"No local disks found error" occurs when attempting to wipe the configuration of a clustered system
784
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • New Setup
  • Storage
Issue
  • The node that has been initialized first can boot up normally.
  • The following error occurs when attempting to wipe the configuration on partner node.
Example:
 * Press Ctrl-C for Boot Menu. *
 Attempting to use existing varfs on /dev/nvrd1
 No SVM keys found.
 Boot Menu will be available.
 Firewall rules loaded.
 Battery charge capacity: 3584 mA*hr. Power outage protection flash de-staging cycles: 51
 Please choose one of the following:
 (1) Normal Boot.
 (2) Boot without /etc/rc.
 (3) Change password.
 (4) Clean configuration and initialize all disks.
 (5) Maintenance mode boot.
 (6) Update flash from backup config.
 (7) Install new software first.
 (8) Reboot node.
 Selection (1-8)? 4
Zero disks, reset config and install a new file system?: yes
This will erase all the data on the disks, are you sure?: yes
Rebooting to finish wipeconfig request
 Assigned 0 out of 3 disks requestedfm_run0: no local disks found & OFW channel is not up.
 [localhost:cf.fm.noMBDisksOrIc:error]: Could not find the local mailbox disks. Could not determine the firmware state of the partner through the HA interconnect.
 WARNING: there do not appear to be any disks attached to the system.
 System halting...
 BIOS version: 9.5
 Portions Copyright (c) 2011-2014 NetApp. All Rights Reserved
 Phoenix SecureCore Tiano(TM)
 Copyright 1985-2020 Phoenix Technologies Ltd.
 All Rights Reserved
  • Check if all the disks are assigned to the initialized node by executing disk show -v command in maintenance mode.
Example:
*> disk show -v
 Local System ID: 123456789
   DISK       OWNER                    POOL   SERIAL NUMBER         HOME                     DR HOME                CHKSUM
 0d.13.5                (987654321)    Pool0  Z1ZBB111           (987654321)                          Block
 0d.12.2                (987654321)    Pool0  Z1ZBB222           (987654321)                          Block
 0d.12.1                (987654321)    Pool0  Z1ZBB333           (987654321)                          Block
 0d.12.4                (987654321)    Pool0  Z1ZBB444           (987654321)                          Block
 0d.13.22               (987654321)    Pool0  Z1ZBB555           (987654321)                          Block
New to NetApp?
Scan to view the article on your device
