NetApp Knowledge Base
Attention led on and "INVALID CHASSIS CONFIGURATION (Incompatible Partner PCM)" is reported
2,194
Visibility:
Votes:
2
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • Service Processor(SP)
  • Baseboard Management Controller (BMC)
Issue
  • Node front attention led on.
  • EMS reports:
[?] Tue Jun 28 02:22:30 +0000 [node-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 4 Temp) is not readable.
[?] Tue Jun 28 02:22:30 +0000 [node-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 3 Temp) is not readable.
[?] Tue Jun 28 02:22:30 +0000 [node-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 2 Temp) is not readable.
[?] Tue Jun 28 02:22:30 +0000 [node-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 1 Temp) is not readable.[?] Tue Jun 28 02:22:43 +0000 [node-01: rlm_hbtrcv_non_blocking: sp.update.status:debug]: params: {'reason': 'sp_bootup_notify_servprocd: SP online handler has been called  '}
[?] Tue Jun 28 02:22:44 +0000 [node-01: cf_worker: cf.hwassist.notifyCfgSuccess:debug]: params: {'hwtype': 'SP'}
[?] Tue Jun 28 02:23:16 +0000 [node-01: env_mgr: monitor.fan.warning:notice]: multiple fans have failed. Replace it to avoid overheating
[?] Tue Jun 28 02:23:46 +0000 [node-01: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Multiple fans have failed
  • SP-LATEST-IPMI / system sensors show report the inability to read sensors:
PSU2 Bad                 invalid            --
PSU1 Bad                 invalid            --
PSU2                     invalid            --
PSU1                     invalid            --
PSU2 ON                  invalid            --
PSU1 ON                  invalid            --
PSU1 INFO                               FAILED
PSU1 INFO                               FAILED
PSU1 FRU                                MULTIFAULT
PSU2 FRU                                MULTIFAULT
Partner Status           failed             --
PSU1 Present                            PRESENT
PSU1 5V                  init_failed       -- mV       --          --          --          --
PSU1 12V                 init_failed       -- mV       --          --          --          --
PSU1 5V Curr             init_failed       -- mA       --          --          --          --
PSU1 12V Curr            init_failed       -- mA       --          --          --          --
PSU1 Fan 1               init_failed       -- RPM      --          --          --          --
PSU1 Fan 2               init_failed       -- RPM      --          --          --          --
PSU1 Inlet Temp          init_failed       -- C        --          --          --          --
PSU1 Hotspot Temp        init_failed       -- C        --          --          --          --
PSU2 Present                            PRESENT
PSU2 5V                  init_failed       -- mV       --          --          --          --
PSU2 12V                 init_failed       -- mV       --          --          --          --
PSU2 5V Curr             init_failed       -- mA       --          --          --          --
PSU2 12V Curr            init_failed       -- mA       --          --          --          --
PSU2 Fan 1               init_failed       -- RPM      --          --          --          --
PSU2 Fan 2               init_failed       -- RPM      --          --          --          --
PSU2 Inlet Temp          init_failed       -- C        --          --          --          --
PSU2 Hotspot Temp        init_failed       -- C        --          --          --          --
PSU_FAN                  failed             --
Module B Expander Temp   init_failed       -- C        --          --          --          --
Module A Expander Temp   init_failed       -- C        --          --          --          --
Midplane 4 Temp          failed            -- C         0 C         5 C        47 C        52 C
Midplane 3 Temp          failed            -- C         0 C         5 C        47 C        52 C
Midplane 2 Temp          failed            -- C         0 C         5 C        47 C        52 C
Midplane 1 Temp          failed            -- C         0 C         5 C        47 C        52 C
Ambient Temp             init_failed       -- C        --          --          --          --
Internal Shelf           failed             --
  • The following messages are occurring repeatedly in the SP log.
Apr 13 07:42:16 2021 [SP.critical]: Rebooting SP due to loss of ACP comms
Jan  1 00:00:40 1970 [IPMI.notice]: 7b03 | c0 | OEM: ffff70005100 | ManufId: 150300 | SP Reset Internally
Jan  1 00:00:50 1970 [IPMI.notice]: 7c03 | 02 | EVT: 0301ffff | Power_Good | Assertion Event, "State Asserted"
Jan  1 00:00:50 1970 [IPMI.notice]: 7d03 | 02 | EVT: 0301ffff | Power_Proc_OK | Assertion Event, "State Asserted"
Jan  1 00:00:50 1970 [IPMI.notice]: 7e03 | 02 | EVT: 0301ffff | Controller_Fault | Assertion Event, "State Asserted"
Jan  1 00:00:51 1970 [IPMI.notice]: 7f03 | 02 | EVT: 0900ffff | LkWrench_Port_Up | Assertion Event, "Device Disabled"
Jan  1 00:01:02 1970 [SP.notice]: Running primary version 2.10
Jan  1 00:01:05 1970 [SP.normal]: Heartbeat started
Jan  1 00:01:05 1970 [Heartbeat.notice]: Heartbeat start: Set SP time. Old time: Thu Jan  1 00:01:05 1970. New time: Tue Apr 13 07:44:06 2021.
Apr 13 07:44:06 2021 [Heartbeat.notice]: Heartbeat time adjusted: Set SP time. Old time: Thu Jan  1 00:01:05 1970. New time: Tue Apr 13 07:44:06 2021.
Apr 13 07:44:06 2021 [IPMI.notice]: 8003 | 02 | EVT: 6fc22fff | System_FW_Status | Assertion Event, "OnTap Kernel Running"
Apr 13 07:44:06 2021 [IPMI.notice]: 8103 | 02 | EVT: 0300ffff | Controller_Fault | Assertion Event, "State Deasserted"
Apr 13 07:45:09 2021 [IPMI.warning]: FRUID 1 Access error
Apr 13 07:45:30 2021 [ASUP.notice]: First notification email | (INVALID CHASSIS CONFIGURATION (Incompatible Partner PCM)) CRITICAL | Sent
Apr 13 08:00:12 2021 [ASUP.notice]: Reminder email | (INVALID CHASSIS CONFIGURATION (Incompatible Partner PCM)) CRITICAL | Sent
  • Multiple sensors are reporting "Unavailable" in the [ENVIRONMENT] log.
  Shelf temperatures by element:
   [1] 20 C (68 F) (ambient)  Normal temperature range
   [2] 31 C (87 F)  Normal temperature range
   [3] 31 C (87 F)  Normal temperature range
   [4] 33 C (91 F)  Normal temperature range
   [5] 33 C (91 F)  Normal temperature range
   [6] 29 C (84 F)  Normal temperature range
   [7] 34 C (93 F)  Normal temperature range
   [8] 34 C (93 F)  Normal temperature range
   [9] 35 C (95 F)  Normal temperature range
   [10] Unavailable
   [11] Unavailable
   [12] Unavailable
   [13] 42 C (107 F)  Normal temperature range
   [14] 59 C (138 F)  Normal temperature range
   [15] 35 C (95 F)  Normal temperature range
  • The following error may be reported.
HA Group Notification (DISK REDUNDANCY FAILED) ERROR
[svc_queue_thread: callhome.dsk.redun.fault:error]: Call home for DISK REDUNDANCY FAILED
  • Internal shelf 0 IOM module reset frequently.
[node01: storlog_admin: sla.shelf.message:debug]: params: {'type': 'SEVERITY', 'log': 'Thu Jan  1 00:00:00 1970 (    0+00:00:00.484); 02000093; U?; HAL; hal; 04; Module Reboot: Startup type 8-Remote reset'}
[node01: storlog_admin: sla.shelf.message:debug]: params: {'type': 'SEVERITY', 'log': 'Thu Jan  1 00:00:00 1970 (    0+00:00:00.487); 02000093; U?; HAL; hal; 04; Module Reboot: Startup type 8-Remote reset'}
New to NetApp?
