NetApp Knowledge Base
How to troubleshoot E-Series Write back caching forcibly disabled alert
6,496
Visibility:
Votes:
4
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
NetApp E-Series
This article describes the procedure to troubleshoot "Write-Back Caching Forcibly Disabled" on E-Series systems.
Write-back caching was disabled on one or more volumes. This problem can occur for the following reasons:
  • Battery Failure
  • Battery below minimum capacity
  • The cache size memory of the controllers are different
  • Cache Reconfiguration
  • A Cache Data-Restore operation is in progress, which interrupted the normal write-back caching process
  • The space in the cache backup device is insufficient for storing the cache
  • Memory parity error
  • Simplex configuration - cache cannot be mirrored
Important Notes
  • When write-back caching is enabled when volumes are configured, write-back caching improves I/O performance. When write-back caching is disabled, the system goes into write through mode, meaning that the I/O will get acknowledged after it is written to disk rather than when it is written to cache. In such case, I/O performance to the volume or group of volumes can be seriously degraded depending on the drives.
  • The error triggers a critical event.
  • The controller is in the Notified state. When write-back caching is enabled, the system transitions from Notified to Optimal after all volumes configured to use write-back caching are restored.
  • When the system transitions from Notified to Optimal, an information MEL event is logged to show that all normal write-back caching capabilities are restored for all volumes in the system.
  • While in the Notified state, a forced-disable of write-caching on any additional volumes has no effect, and no state transition occurs.
New to NetApp?
