How to check/repair volume parity errors on E-Series arrays running pre-11.80 OS
Applies to
- NetApp E-Series
- All SANtricity OS pre-11.80
This article describes the procedure to check/repair volume parity errors using script editor or SMcli on systems running pre-11.80 OS. The commands provided are deprecated starting with 11.80 OS.
NOTE: If (Data/parity mismatch on volume) CRITICAL event gets reported by ASUP, it is required to execute this procedure.
