NetApp Knowledge Base
E-Series drawer degraded or multiple disk errors on one drawer
3,727
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  • NetApp E-Series
  • SANtricity OS 08.30 and above
  • SANtricity OS 11.30 and above
Issue
  • Recovery Guru reports multiple critical events which reside on a particular drawer. For example, drawer degraded:
Failure Entry 15: DRAWER_DEGRADED-Recovery Failure Type Code: 393
Storage array: array1
Component reporting problem: Drawer 1
Status: Degraded
Component requiring service: Drawer 1
Service action (removal) allowed: No Service action LED on component: No
  • SAS port failed or degraded:
Failure Entry 1: SAS_PORT_FAILED-Recovery Failure Type Code: 113
Port reporting problem:
Drive tray 2, ESM: B (Bottom), Channel 2, Internal connection
Status: SAS Port Failed
Failure Entry 15: SAS_PORT_DEGRADED-Recovery Failure Type Code: 112
Storage array: array2
Drive tray 1, Drawer 1, Channel 2, Internal connection
Status: SAS Port Degraded
  • Loss of Path Redundancy for multiple drives on the particular drawer:
Failure Entry 2: NO_REDUNDANCY_DRIVE-Recovery Failure Type Code: 32
Component reporting problem: Drive in slot 8
Status: Optimal
Component requiring service: Drive in slot 8
Service action LED on component: Yes
Working channel: 0
  • System Manger has a yellow highlight on multiple drives indicating drawer degraded.
New to NetApp?
