NetApp Knowledge Base
E-Series Impending drive failure detected by controller or drive - AutoSupport Message
5,049
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  • NetApp E-Series
  • NetApp StorageGRID Appliances
Event Summary
  • SANtricity reports a impending drive failure, this means that the drive could/should fail soon.
  • StorageGRID Grid Manager report alert: Appliance storage controller drive failure
  • The data on the drive is still available to the E-Series system.
Validate
  1. Login to SANtricity Storage Manager or SANtricity System Manager
  2. Verify from the Hardware page if the disk shows as impending failure
  3. The event log should report one or more of the following errors:
    • Event type: 2285 Description: Impending drive failure detected by drive
    • Event type:101f Description: Summary of impending drive failure detected by controller
    • Event type: 1023 Description: Drive copy triggered by a controller detected impending drive failure
Resolution
  1. Monitor the system and check within several hours drive should fail.
  2. Replace the drive once it fails.
Additional Information
Diagnosing an impending drive failure on E-Series platforms
WARNING
Only perform this action when instructed by NetApp Technical Support.
  1. It might be required to manually fail the drive if the data copy is not progressing, takes a long time, or is on hold and a replacement is ready to be installed. Please follow below steps after confirming the volumes are not in a degraded state:
    1. In SANtricity System Manager, navigate to the Hardware tab.
    2. Select the drive in question, then select Cancel Fail.
    3. Manually fail the drive with Copy contents of drive before failing unselected.
  2. If multiple drives are going into impending failure,  replace them one by one and not all at the same time. The failures may be firmware-related and require to also upgrade to latest FW
New to NetApp?
