NetApp Knowledge Base
Can direct-attached storage (DAS) ONTAP Select and Deploy instances be vMotioned when upgrading ESX firmware?
738
Visibility:
Votes:
0
Category:
ontap-select
Specialty:
ontapselect
Last Updated:
Applies to
  • ONTAP Select
  • ONTAP Deploy
  • ESXi
  • VMware
Answer
DAS ONTAP Select HA nodes cannot be vmotioned.
  • Takeover/Givebacks will need to be completed during the ESXi firmware upgrade.
ONTAP Deploy can be Vmotioned prior to the upgrade.
  • It's recommended it be done cold by powering down the Deploy node, vMotion, then power on. (This is non-disruptive to the HA cluster)
Additional Information
  • The upgraded ESX image must have the vendor RAID controller driver installed, so it will need to be downloaded from the ESX vendor. Do not use the vmware image.
  • NetApp Interoperability Matrix can be used to verify the ONTAP Select/Deploy versions are supported with the new ESX image version.
  • ONTAP Select on VMware
