Why is my aggregate showing 10% less total space than expected?
Applies to
ONTAP 9
Answer
- The WAFL file system automatically reserves 10% of the aggregate space for metadata and performance.
- Beginning in ONTAP 9.12.1, the WAFL reserve for aggregates greater than 30TB is reduced to 5% for All Flash FAS (AFF) and the FAS500f platforms.
- Beginning in ONTAP 9.14.1, this same reduction applies to aggregates on all FAS platforms, resulting in 5% more usable space in the aggregates.
- The space used for maintaining the volumes in the aggregate comes out of the WAFL reserve and the WAFL reserve cannot be changed.
