NetApp Knowledge Base
When Should I Not Consider Enabling Compression and/or Deduplication?
532
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
ONTAP 9
Answer
Some examples of when not to use deduplication on a volume include:
  • Savings less than the amount of deduplication metadata,
  • Data is being overwritten at a rapid rate.
Some examples of when not to use compression on a volume include:
  • Large number of small overwrites of a file (typically if overwrite is <32KB),
  • Majority of files are 8KB or less,
  • Highly latency sensitive applications (validate performance with testing to see if acceptable or not).
Additional Information
Find additional information here.
