NetApp Knowledge Base
Cannot unjoin node from cluster after initializing node without unjoining
2,967
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9.10.1 and earlier
  • Four-node cluster
Issue
In the specific case of a four-node-cluster:
  • A node and it's HA partner is wiped or differently removed without unjoining first
  • Cluster quorum might get lost if Epsilon was not placed on either of the two remaining nodes
  • Subsequently attemping to unjoin the nodes will fail with the following error:
::*> cluster unjoin -node Cluster-node-3 -force
Warning: This command will forcibly unjoin node "Cluster-node-3" from the
         cluster. You must unjoin the failover partner as well. This will
         permanently remove from the cluster any volumes that remain on that
         node and any logical interfaces with that node as the home-node.
         Contact support for additional guidance.
Do you want to continue? {y|n}: y
[Job 615] Checking prerequisites
Error: command failed: [Job 615] Job failed: This command requires that
       management services be online on at least 3 of the 4 eligible nodes,
       excluding "Cluster-node-3". Currently, there are only 2 healthy nodes
       after excluding "Cluster-node-3". Please repair the unhealthy nodes, and
       reissue the command.
New to NetApp?
