NetApp Knowledgebase
Troubleshooting Workflow: Node is out of CLAM quorum for clusters running Data ONTAP 8.3 and later
610
Visibility:
Votes:
0
Category:
data-ontap-8
Specialty:
core
Last Updated:
Applies to
A node is out of 'CLAM quorum'.
AutoSupport: NODE(S) OUT OF CLUSTER QUORUM
Issue
Connectivity, Liveness, Availability Monitor (CLAM), are functions of clustered Data ONTAP 8 and is used by each node in the cluster to monitor the availability of the other nodes. When CLAM detects a communication fault on the cluster network or a node outage it will initiate an HA takeover of the isolated node(s) to maintain the service of the faulted node(s) data.
As of Data ONTAP 8.1, CLAM will only initiate an HA takeover if FCP or iSCSI is licensed and the node has LUNs or SAN LIFs. Each node in the cluster will generate and send an AutoSupport with the reason NODE(S) OUT OF CLUSTER QUORUM containing the diagnostic data needed to identify the cause of the fault.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
