NetApp Knowledge Base
How to use the boot_recovery LOADER command for installing ONTAP for initial setup of a system
1,668
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • AFF A700, AFF A700s, AFF A300, AFF A200 and later models
  • FAS9000, FAS8200, FAS2650, FAS2620 and later models
When setting up a new ONTAP cluster or repurposing an HA Pair some AFF and FAS models support the use of a USB flash drive to perform the boot_recovery procedure to install the desired version of ONTAP.
Note:  This will remove all configuration from the system.  Only perform for new controller setup or during the repurpose process.
New to NetApp?
Scan to view the article on your device
