NetApp Knowledge Base
ONTAP 9 Performance - Resolution Path
33,920
Visibility:
Votes:
20
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • ONTAP 9
  • FAS
  • AFF
  • NetApp Cloud Volumes ONTAP
  • NetApp ONTAP Select
  • This article guides troubleshooting and references other articles for the same procedures Support uses to troubleshoot performance issues
  • Performance issues are typically:
    • Job run time is longer than expected or job time is delayed, slower than expected throughput, or higher than expected latency on ONTAP or client side
    • Utilization is higher or at 100% of a processing center (CPU/disk)
    • Slow backups
    • Degraded or poor performance
New to NetApp?
