How to set pre-boot environment variables for NetApp Storage Encryption using KMIP servers
Applies to
- Clustered Data ONTAP 8
- NetApp Storage Encryption
Setting pre-boot environmental variables are necessary for NetApp Storage Encryption (NSE) storage systems. The NSE bootarg 'bootarg.storageencryption.support true
' is set at the factory if NSE drives are present in the controller. The other bootargs listed below are automatically created when the key_manager setup
(nodeshell 7-Mode) or the security key-manager setup
(clustered Data ONTAP 8.3.1 and later) command is run.
If the storage system is unable to correctly contact the KMIP Key Management Server, it will not be able to boot. This is because the required boot information cannot be decrypted and will, therefore, be unreadable.
