NetApp Knowledge Base
How to rotate data authentication keys on a FIPS drive or SED
2,862
Visibility:
Votes:
2
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • External Key Manager
  • Onboard Key Manager (OKM)
  • NetApp Storage Encryption (NSE)
  • ONTAP 9 and later
  • At times, it may be desirable to rotate data authentication keys on a FIPS drive or SED.
  • The process of rotating keys in an NSE environment depends on whether you are using an External Key Manager (using KMIP) or the OKM.
    • External Key Managers require generating a new authentication key (AK) before assigning new authentication keys to the drives.
    • OKM does not support generating new authentication keys without deleting and recreating the OKM configuration on the cluster.
New to NetApp?
