NetApp Knowledge Base
How to measure CPU utilization
26,106
Visibility:
Votes:
17
Category:
clustered-data-ontap-8
Specialty:
Perf
Last Updated:
Applies to
ONTAP 9
Answer
  1. Using sysstat -M 1
::> set diag
Warning: These diagnostic commands are for use by NetApp personnel only.
Do you want to continue? {y|n}: y
::*> node run -node netapp-01 sysstat -M 1
ANY1+ ANY2+ ANY3+ ANY4+ ANY5+ ANY6+ ANY7+ ANY8+ ANY9+ ANY10+ ANY11+ ANY12+ ANY13+ ANY14+ ANY15+ ANY16+  AVG
 100%  100%  100%   99%   98%   96%   94%   91%   86%    81%    76%    70%    64%    57%    48%   37%   81%
CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7 CPU8 CPU9 CPU10 CPU11 CPU12 CPU13 CPU14 CPU15
 78%  76%  77%  83%  82%  83%  82%  82%  82%  82%   83%   84%   83%   82%   83%   82%
Nwk_Excl Nwk_Lg Nwk_Exmpt Protocol Cluster Storage Raid Raid_Ex Target Kahuna WAFL_Ex(Kahu)
      3%     2%      450%       0%      0%     49%   2%    136%     0%     4%    511%( 94%)
WAFL_XClean SM_Exempt Cifs Exempt SSAN_Ex Intr Host  Ops/s   CP
         0%        0%   0%   112%      0%  28%   8%  47111   0%
  • In the above example, Average CPU Utilization is 81% across the 16 cores
Busiest domains:
  • WAFL exempt at 511%
  • Networking exempt at 450%
  • RAID exempt at 136%, and exempt at 112%.
  • WAFL was active 98% (Kahu+Kahuna) of the sample interval, with 4% (Kahuna) spent in serial processing and 94% (Kahu) in parallel processing
  • WAFL serial processing being quite low, it is likely that more work could be completed by parallelized WAFL
  • Being 98% active within the sample interval is not a concern without other contributing performance indicators
  • Overall CPU resources get scarce, increasing the likelihood of work queuing for CPU, potentially impacting client latency
  1. Using sysstat - x 1
::> set diag
::*> node run -node cluster1-01 sysstat -x 1
 CPU    NFS   CIFS   HTTP   Total     Net   kB/s    Disk   kB/s    Tape   kB/s   Cache  Cache    CP
                                       in    out    read  write    read  write     age    hit  time
  2%      0      0      0      24       7      7      12       0       0      0   >60    100%    0%
  2%      0      0      0       5      11      4       0      24       0      0   >60    100%    0%
  4%      0      0      0       0       9      9      20    1274       0      0   >60    100%    1%
  4%      0      0      0       3       7      8      12      36       0      0   >60      -     0%
  1%      0      0      0       1       4      5       0       0       0      0   >60    100%    0%
  2%      0      0      0      20       6      5       0       0       0      0   >60      -     0%
  5%      0      0      0       8       5      6      12      24       0      0   >60      -     0%
  1%      0      0      0       0      12     13      12       0       0      0   >60      -     0%
  2%      0      0      0       0       3      4       0      36       0      0   >60      -     0%
  • In the above example, CPU Utilization can be viewed from the first column which is 2%
