Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
How to convert a clustered Data ONTAP 8.x node to a 7-Mode node
1,318
Visibility:
Votes:
1
Category:
data-ontap-8
Specialty:
core
Last Updated:
Applies to
Data ONTAP
There are two operation modes to NetApp's Data ONTAP OS. When a storage system is shipped from the factory, the Data ONTAP mode is set according to the sales order.
Sometimes, it becomes necessary to convert a storage system DATA ONTAP operation mode from clustered Data ONTAP to Data ONTAP 7-Mode.
This article describes the procedure to convert the storage system from clustered Data ONTAP to Data ONTAP 7-Mode.
This procedure is disruptive and will wipe clean all assign Disks.
Warning: To prevent data loss, it is wise the save all data outside this system scope.
Note: After this procedure, you might also need to revert the Data ONTAP version to an earlier version using the revert_to command. You might also need to convert your licenses.
New to NetApp?
Scan to view the article on your device
